Saltar al contenido principal
Velocity Micro Cruz Camera Replacement
Qué necesitas
  1. Velocity Micro Cruz Camera Replacement, Remove the Back: paso 1, imagen 1 de 1
    • Using one of the plastic opening tools, separate the plastic back from the tablet in one spot.
    • Gently work the tool around the diameter of the tablet until the back pops completely off.
  2. Velocity Micro Cruz Camera Replacement, Accessing the Camera: paso 2, imagen 1 de 2 Velocity Micro Cruz Camera Replacement, Accessing the Camera: paso 2, imagen 2 de 2
    • Locate the camera as illustrated. Remove the 3 black screws at the top of the tablet.
    • Gently pull back the yellow piece so that the camera may be accessed.
  3. Velocity Micro Cruz Camera Replacement, Remove the Camera: paso 3, imagen 1 de 2 Velocity Micro Cruz Camera Replacement, Remove the Camera: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to pull back the black latch on the motherboard that holds the camera.
    • Finally, use the tweezers to remove the camera from the motherboard.
Conclusión
T Smith
Miembro Desde 11/02/16
205 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 83
