Saltar al contenido principal
VanMoof No 3 Light Battery Replacement
Qué necesitas
  1. VanMoof No 3 Light Battery Replacement, Battery: paso 1, imagen 1 de 3 VanMoof No 3 Light Battery Replacement, Battery: paso 1, imagen 2 de 3 VanMoof No 3 Light Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Buy two, "2/3" AAA NiCad rechargeable batteries. Better still get four so you can replace the batteries in both lights.
    • Get the batteries with solder tabs
  2. VanMoof No 3 Light Battery Replacement, Disassemble the light: paso 2, imagen 1 de 1
    • Nothing to it really - just remove the 2 cross point screws
  3. VanMoof No 3 Light Battery Replacement, Remove the battery: paso 3, imagen 1 de 2 VanMoof No 3 Light Battery Replacement, Remove the battery: paso 3, imagen 2 de 2
    • Use a flat blade screw driver to pull the battery from the adhesive tape.
    • Remove the heat shrink plastic joining the batteries
  4. VanMoof No 3 Light Battery Replacement, Unsolder the battery: paso 4, imagen 1 de 2 VanMoof No 3 Light Battery Replacement, Unsolder the battery: paso 4, imagen 2 de 2
    • Unsolder the wires
  5. VanMoof No 3 Light Battery Replacement, Solder the new battery: paso 5, imagen 1 de 3 VanMoof No 3 Light Battery Replacement, Solder the new battery: paso 5, imagen 2 de 3 VanMoof No 3 Light Battery Replacement, Solder the new battery: paso 5, imagen 3 de 3
    • Tin the battery tabs
    • Join together with tape. You'll remove this later. Both +ve ends are joined
    • The red wire goes on the end of the battery that has a ridge.
  6. VanMoof No 3 Light Battery Replacement, Join the batteries: paso 6, imagen 1 de 1
    • Remove the temporary tape
    • Fold the tabs inwards
    • Cover with 2 pieces of insulation tape. The wires will come out of the middle, between the pieces of tape
  7. VanMoof No 3 Light Battery Replacement, Reassemble: paso 7, imagen 1 de 3 VanMoof No 3 Light Battery Replacement, Reassemble: paso 7, imagen 2 de 3 VanMoof No 3 Light Battery Replacement, Reassemble: paso 7, imagen 3 de 3
    • Put the small black cup back on the switch. The dome goes outwards.
    • Put the outer switch in the lense. It goes in the smaller hole
    • The black body will be flush when it's pushed together.
  8. VanMoof No 3 Light Battery Replacement, Reassemble 2: paso 8, imagen 1 de 2 VanMoof No 3 Light Battery Replacement, Reassemble 2: paso 8, imagen 2 de 2
    • Test the light turns on
    • Screw the back plate to the lense.
Conclusión
3 personas más completaron esta guía.
Martin Hampton
Miembro Desde 02/13/16
1,308 Reputación
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 42
Ultimos 30 días: 130
Todo El Tiempo: 7,697
