Saltar al contenido principal
Valve Index Controller Right Hand Strap Replacement
Qué necesitas
  1. Valve Index Controller Right Hand Strap Replacement, Remove the elastic band: paso 1, imagen 1 de 3 Valve Index Controller Right Hand Strap Replacement, Remove the elastic band: paso 1, imagen 2 de 3 Valve Index Controller Right Hand Strap Replacement, Remove the elastic band: paso 1, imagen 3 de 3
    • Press and hold the elastic band adjustment button.
    • Slide the elastic band out of the controller.
    • During reassembly, pinch the elastic band near the tip of the loop and slide it into the controller.
  2. Valve Index Controller Right Hand Strap Replacement, Insert an opening pick: paso 2, imagen 1 de 3 Valve Index Controller Right Hand Strap Replacement, Insert an opening pick: paso 2, imagen 2 de 3 Valve Index Controller Right Hand Strap Replacement, Insert an opening pick: paso 2, imagen 3 de 3
    • Insert an opening pick under the round plastic cover next to the A and B buttons.
    • Do not insert the opening pick more than 5 mm (0.2 in) into the controller, or you may tear the touchpad ribbon cable.
    • Slide the opening pick around the top of the controller until all three plastic clips are disengaged.
  3. Valve Index Controller Right Hand Strap Replacement, Open the controller: paso 3, imagen 1 de 2 Valve Index Controller Right Hand Strap Replacement, Open the controller: paso 3, imagen 2 de 2
    • Carefully open the top of the controller to access the screws inside.
    • Be careful not to strain or tear the ribbon cable connected to the touchpad.
  4. Valve Index Controller Right Hand Strap Replacement, Unscrew the adjustment strap: paso 4, imagen 1 de 2 Valve Index Controller Right Hand Strap Replacement, Unscrew the adjustment strap: paso 4, imagen 2 de 2
    • Use a T5 Torx screwdriver to remove the two 6.1 mm screws securing the adjustment strap to the controller.
    • Once the adjustment strap is unscrewed, the spring underneath may fall out.
    • Make sure the spring is installed during reassembly, or the ratcheted adjustment mechanism will not work properly.
  5. Valve Index Controller Right Hand Strap Replacement, Remove the adjustment strap: paso 5, imagen 1 de 2 Valve Index Controller Right Hand Strap Replacement, Remove the adjustment strap: paso 5, imagen 2 de 2
    • Slide the adjustment strap out from the controller to remove it.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
2 personas más completaron esta guía.
Sam Omiotek
Miembro Desde 02/25/19
65,158 Reputación
288 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 70
Ultimos 30 días: 302
Todo El Tiempo: 5,933
