Saltar al contenido principal
Vacuum Cleaner Brush Roll Replacement
Qué necesitas
  1. Vacuum Cleaner Brush Roll Replacement, Brush Roll: paso 1, imagen 1 de 1
    • Be sure to unplug the device from the wall outlet before disassembling.
    • Remove the bottom head of the vacuum cleaner by pressing the push button.
  2. Vacuum Cleaner Brush Roll Replacement: paso 2, imagen 1 de 2 Vacuum Cleaner Brush Roll Replacement: paso 2, imagen 2 de 2
    • Carefully unscrew the 6 screws with a Phillips screwdriver. Set aside.
  3. Vacuum Cleaner Brush Roll Replacement: paso 3, imagen 1 de 1
    • Separate the top portion of the head from the bottom.
    • Make sure not to pull off or damage the connected wires.
  4. Vacuum Cleaner Brush Roll Replacement: paso 4, imagen 1 de 1
    • Slip off the belt.
  5. Vacuum Cleaner Brush Roll Replacement: paso 5, imagen 1 de 2 Vacuum Cleaner Brush Roll Replacement: paso 5, imagen 2 de 2
    • Pull the brush roll from its slots.
  6. Vacuum Cleaner Brush Roll Replacement: paso 6, imagen 1 de 2 Vacuum Cleaner Brush Roll Replacement: paso 6, imagen 2 de 2
    • Use scissors to cut strings and other debris from the brush roll. Avoid cutting the bristles.
  7. Vacuum Cleaner Brush Roll Replacement: paso 7, imagen 1 de 1
    • Return the clean brush roll and re-situate the belt to secure it in place.
Conclusión
To reassemble your device, follow the disassembly instructions in reverse order.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 48
Todo El Tiempo: 3,177
