Saltar al contenido principal
VTechCS6719-16 Ringer Replacment
Qué necesitas
  1. VTechCS6719-16 Ringer Replacment, Ringer: paso 1, imagen 1 de 1
    • Remove sliding back cover from case.
  2. VTechCS6719-16 Ringer Replacment: paso 2, imagen 1 de 1
    • Lift the battery and unplug the two pin cable from phone base.
  3. VTechCS6719-16 Ringer Replacment: paso 3, imagen 1 de 1
    • Slide back cover off the phone
    • Located at the bottom of the frame are the two-10 mm screws.
    • Use a Phillips head screwdriver to remove both 10 mm screws.
    • It is recommended to use a magnetic mat or place the screws on an easy to see surface. They will be needed when the phone is reassembled.
  4. VTechCS6719-16 Ringer Replacment: paso 4, imagen 1 de 1
    • After removing the two screws from the back of the phone carefully use the metal spudger to lift along the edges and raise the phone case from the internal clips.
  5. VTechCS6719-16 Ringer Replacment: paso 5, imagen 1 de 1
    • Once the case is lifted, the board should be freed except for the connection between the ringer and the case.
    • Be careful do not pull the case away from the phone in a jerking or aggressive motion.
  6. VTechCS6719-16 Ringer Replacment: paso 6, imagen 1 de 1
    • Using the spudger lift the latch over the ringer to release it.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger should be used whenever possible.
  7. VTechCS6719-16 Ringer Replacment: paso 7, imagen 1 de 1
    • The last component of the latch is soldered to the circuit board. This will take some soldering expertise.
Conclusión
Charles montes
Miembro Desde 10/20/16
513 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 5-5, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-5, Martin Fall 2016
UMASSD-MARTIN-F16S5G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 219
