Saltar al contenido principal
VTech Touch and Swipe Baby Phone Battery Replacement
Qué necesitas
  1. VTech Touch and Swipe Baby Phone Battery Replacement, Battery: paso 1, imagen 1 de 2 VTech Touch and Swipe Baby Phone Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. VTech Touch and Swipe Baby Phone Battery Replacement: paso 2, imagen 1 de 3 VTech Touch and Swipe Baby Phone Battery Replacement: paso 2, imagen 2 de 3 VTech Touch and Swipe Baby Phone Battery Replacement: paso 2, imagen 3 de 3
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. VTech Touch and Swipe Baby Phone Battery Replacement: paso 3, imagen 1 de 3 VTech Touch and Swipe Baby Phone Battery Replacement: paso 3, imagen 2 de 3 VTech Touch and Swipe Baby Phone Battery Replacement: paso 3, imagen 3 de 3
    • When reassembling, align the notch on the battery panel with the slot on the phone.
Conclusión
Una persona más ha completado esta guía.
Zack Drawdy
Miembro Desde 09/04/15
231 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 2-4, Sullivan Fall 2015 Miembro de USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 Miembros
12 Guías creadas
2 comentarios
Seems this device is VERY sensitive to low batteries. An issue I assumed was the power switch (randomly turning off) was actually batteries. Also hilarious this has an iFixit page.
Chris Uthe - Contestar
Thank you! Changing the batteries fixed the loop issue
Jessica Dorado - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 1,075
