Saltar al contenido principal
VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement
Qué necesitas
  1. VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Expose the battery compartment by removing the lower back cover of the device.
    • Do this by holding the back side of the device upside down in your hands and applying pressure to the indented portion with both thumbs.
  2. VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement: paso 2, imagen 1 de 1
    • Once the batteries are exposed, use your index finger to push the battery against the spring and pull up to dislodge the battery.
    • Make sure to check for battery acid or other corrosive substances before touching the battery. If needed, use latex gloves to avoid skin irritation from battery acid.
  3. VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement, Parent Unit Motherboard: paso 3, imagen 1 de 3 VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement, Parent Unit Motherboard: paso 3, imagen 2 de 3 VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement, Parent Unit Motherboard: paso 3, imagen 3 de 3
    • Use a plastic opening tool to gently pry along the middle of the 2 sections of the plastic housing in order to release plastic latches on the inside of the housing.
    • Do not take apart briskly or separate the two units completely as they are connected by thin wires.
  4. VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement: paso 4, imagen 1 de 2 VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement: paso 4, imagen 2 de 2
    • Gently pull apart the two housing component taking care not to damage the wire connecting them.
    • Check the wire connections from the battery compartment to the motherboard for any cuts, burn marks, or loose wires.
    • Likewise check the soldering joints for the antenna, and the power jack, and speakers, in order to make surethe issue is with the motherboard and not the wires or other components.
  5. VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement: paso 5, imagen 1 de 2 VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement: paso 5, imagen 2 de 2
    • Free the motherboard by unscrewing the two 4mm phillips head screws at the top of the motherboard
    • Flip over the motherboard and de-solder the wires connecting the speaker to the motherboard
Conclusión
Jean Carlos
Miembro Desde 08/31/15
201 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 6-3, Remmell Fall 2015 Miembro de USF Tampa, Team 6-3, Remmell Fall 2015
USFT-REMMELL-F15S6G3
4 Miembros
7 Guías creadas
Un comentario
After changing the motherboard I can no longer get the device to link to the baby monitor
Hyrum Clark - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 1,337
