Saltar al contenido principal
Introducción
Use this guide to replace the battery if the device shuts off during use or will not turn on. Be careful while removing the battery, make sure to check for signs of corrosion or battery acid. once the batteries have been removed make sure to replace them with alkaline batteries.
  1. Expose the battery compartment by removing the lower back cover of the device.
    • Expose the battery compartment by removing the lower back cover of the device.
    • Do this by holding the back side of the device upside down in your hands and applying pressure to the indented portion with both thumbs.
  2. Once the batteries are exposed, use your index finger to push the battery against the spring and pull up to dislodge the battery.
    • Once the batteries are exposed, use your index finger to push the battery against the spring and pull up to dislodge the battery.
    • Make sure to check for battery acid or other corrosive substances before touching the battery. If needed, use latex gloves to avoid skin irritation from battery acid.
Conclusión
Darrell Griffin
Miembro Desde 31/08/15
201 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 6-3, Remmell Fall 2015 Miembro de USF Tampa, Team 6-3, Remmell Fall 2015
USFT-REMMELL-F15S6G3
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 15
Ultimos 30 días: 63
Todo El Tiempo: 3,092
