Saltar al contenido principal
VTech Safe And Sound DM221 Speaker Replacement
Qué necesitas
  1. VTech Safe And Sound DM221 Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Remove the battery cover.
  2. VTech Safe And Sound DM221 Speaker Replacement: paso 2, imagen 1 de 1
    • Unplug the battery from its connector and remove.
  3. VTech Safe And Sound DM221 Speaker Replacement: paso 3, imagen 1 de 1
    • Using the Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws at the bottom of the monitor.
  4. VTech Safe And Sound DM221 Speaker Replacement: paso 4, imagen 1 de 1
    • Separate the back half of the device from the front using the metal spudger.
  5. VTech Safe And Sound DM221 Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the two 5.0 mm Phillips #00 screws at the top of the device which holds the antenna at the top of the motherboard.
    • This will allow the removal of the silver handle.
  6. VTech Safe And Sound DM221 Speaker Replacement: paso 6, imagen 1 de 1
    • Remove the “TALK” button to get access to remove the motherboard.
  7. VTech Safe And Sound DM221 Speaker Replacement: paso 7, imagen 1 de 1
    • Push down on the antenna, located on the top of the motherboard.
  8. VTech Safe And Sound DM221 Speaker Replacement: paso 8, imagen 1 de 1
    • Gently remove the motherboard away from the monitor.
    • Be careful not to disconnect the red wire.
  9. VTech Safe And Sound DM221 Speaker Replacement: paso 9, imagen 1 de 1
    • Use the plastic spudger to push the two white plastic tabs, at the bottom of the device, up to release the metal retaining clip.
Conclusión
Krystal
Miembro Desde 10/01/15
600 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-5, Leahy Fall 2015 Miembro de USF Tampa, Team 1-5, Leahy Fall 2015
USFT-LEAHY-F15S1G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 342
