Introducción
Is your antenna not picking up the monitor signal? Read this repair guide to find out how to replace your antenna.
Qué necesitas
Remove the battery cover by sliding it down.
Firmly grasp the battery and pull to disconnect the battery from its connector.
Using a Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws located at the bottom of the monitor inside of the device.
Un comentario
Great tutorial thanks! What type of antenna should I replace it with to get better reception?
