Saltar al contenido principal
VTech Kidizoom Smartwatch DX2 Wristband Replacement
Qué necesitas
  1. VTech Kidizoom Smartwatch DX2 Wristband Replacement, Wristband: paso 1, imagen 1 de 1
    • Begin by placing the watch on its side.
  2. VTech Kidizoom Smartwatch DX2 Wristband Replacement: paso 2, imagen 1 de 1
    • Next, use the flat end of the spudger to wedge between the small-headed pin (located on the band closest to the watch) to pull the pin up through the other side.
  3. VTech Kidizoom Smartwatch DX2 Wristband Replacement: paso 3, imagen 1 de 1
    • Pull the pin out, however not fully, feeling slight resistance is normal.
  4. VTech Kidizoom Smartwatch DX2 Wristband Replacement: paso 4, imagen 1 de 1
    • Finally, pull the wristband off. Repeat on the opposite side of the watch if necessary.
Conclusión
Sydney
Miembro Desde 10/25/18
323 Reputación
2 Guías creadas
Equipo
Un comentario
My Vtech DX2 had a split pin. One side of the pin was the long side and the other very very short. So look out for that. Thanks for this tutorial, was very helpful.
Ryan Laurel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 84
Todo El Tiempo: 6,972
