Saltar al contenido principal
VTech Kidizoom Smartwatch DX2 Motherboard Replacement
Qué necesitas
  1. VTech Kidizoom Smartwatch DX2 Motherboard Replacement, Master Switch: paso 1, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Motherboard Replacement, Master Switch: paso 1, imagen 2 de 2
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: paso 2, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: paso 2, imagen 2 de 2
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: paso 3, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: paso 3, imagen 2 de 2
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: paso 4, imagen 1 de 3 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: paso 4, imagen 2 de 3 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: paso 4, imagen 3 de 3
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: paso 6, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: paso 6, imagen 2 de 2
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: paso 7, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: paso 7, imagen 2 de 2
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
Conclusión
4 personas más completaron esta guía.
Jessica Richard
Miembro Desde 10/25/18
512 Reputación
4 Guías creadas
Equipo
2 comentarios
This shows how to take the motherboard out, but how to I get a replacement motherboard? I don’t see anywhere that I can purchase one…
ltiede12 - Contestar
I’m interested in the components on the motherboard. What type of SOC does it use, what operating system, etc…
Asher Kobin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 33
Todo El Tiempo: 3,506
