Saltar al contenido principal
VTech Kidizoom Smartwatch DX2 Faceplate Replacement
Qué necesitas
  1. VTech Kidizoom Smartwatch DX2 Faceplate Replacement, Faceplate: paso 1, imagen 1 de 1
    • In order to remove the faceplate you must start by placing the watch screen upwards.
  2. VTech Kidizoom Smartwatch DX2 Faceplate Replacement: paso 2, imagen 1 de 1
    • Use iFixit’s opening tool, another similar tool, or simply use your fingernail to gently pry open the faceplate away from the screen starting from an edge.
    • You may hear a popping sound, but this is normal.
  3. VTech Kidizoom Smartwatch DX2 Faceplate Replacement: paso 3, imagen 1 de 1
    • Once successful, pull the remaining faceplate off from the watch.
Conclusión
Una persona más ha completado esta guía.
Jessica Richard
Miembro Desde 10/25/18
512 Reputación
4 Guías creadas
Equipo
4 comentarios
Where can I find a faceplate?
Sammi Schummer - Contestar
Where can you buy a replacement face plate?
Natalie - Contestar
This doesn't remove the faceplate, just the decorative bezel around the screen. I'm looking for disassembly instructions to open up the screen as my son wore his I to the pool (immediately after being told not to! Kids…)
Jack Wesselo - Contestar
Where can I get a replacement faceplate please
Steph Crowe - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 2,635
