Saltar al contenido principal
VTech Kidizoom Smartwatch DX2 Camera Replacement
Qué necesitas
  1. VTech Kidizoom Smartwatch DX2 Camera Replacement, Master Switch: paso 1, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Camera Replacement, Master Switch: paso 1, imagen 2 de 2
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Camera Replacement: paso 2, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Camera Replacement: paso 2, imagen 2 de 2
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Camera Replacement: paso 3, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Camera Replacement: paso 3, imagen 2 de 2
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Camera Replacement: paso 4, imagen 1 de 3 VTech Kidizoom Smartwatch DX2 Camera Replacement: paso 4, imagen 2 de 3 VTech Kidizoom Smartwatch DX2 Camera Replacement: paso 4, imagen 3 de 3
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Camera Replacement, Motherboard: paso 5, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Camera Replacement: paso 6, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Camera Replacement: paso 6, imagen 2 de 2
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Camera Replacement: paso 7, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Camera Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
  8. VTech Kidizoom Smartwatch DX2 Camera Replacement, Camera: paso 8, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Camera Replacement, Camera: paso 8, imagen 2 de 2
    • Turn the motherboard so the battery is on the bottom and locate the two clips holding the cameras in place.
    • Carefully lift the clips and slide the cameras out.
Conclusión
Nathaniel Cady
Miembro Desde 10/26/18
187 Reputación
1 Guía escrita
Equipo
Un comentario
to much and do not under stand it
Aaron Arora - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 817
