Saltar al contenido principal
VTech Kidizoom Smartwatch DX2 Battery Replacement
Qué necesitas
  1. VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: paso 1, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: paso 1, imagen 2 de 2
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Battery Replacement: paso 2, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: paso 2, imagen 2 de 2
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Battery Replacement: paso 3, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: paso 3, imagen 2 de 2
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Battery Replacement: paso 4, imagen 1 de 3 VTech Kidizoom Smartwatch DX2 Battery Replacement: paso 4, imagen 2 de 3 VTech Kidizoom Smartwatch DX2 Battery Replacement: paso 4, imagen 3 de 3
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Battery Replacement, Motherboard: paso 5, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Battery Replacement: paso 6, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: paso 6, imagen 2 de 2
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Battery Replacement: paso 7, imagen 1 de 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: paso 7, imagen 2 de 2
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
  8. VTech Kidizoom Smartwatch DX2 Battery Replacement, Battery: paso 8, imagen 1 de 1
    • Carefully pry the battery off of the circuit board using the plastic opening tool.
  9. VTech Kidizoom Smartwatch DX2 Battery Replacement: paso 9, imagen 1 de 1
    • De-solder the wires connecting the battery to the circuit board.
    • Remove the battery.
Conclusión
Jessica Richard
Miembro Desde 10/25/18
512 Reputación
4 Guías creadas
Equipo
4 comentarios
Hey guys, My VTech watch is plugged in but once I turn it on it does but then shows a dead battery. I actually didn’t play with it for a while and I left it dead battery.
Gabriel Baker - Contestar
So I might try this trick and see if it works.
Sometime i’ll try it
when I have the right tools
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 37
Ultimos 30 días: 191
Todo El Tiempo: 7,500
