Saltar al contenido principal
VTech Kidizoom Camera Connect Shutter Button Replacement
Qué necesitas
  1. VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: paso 1, imagen 1 de 2 VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: paso 1, imagen 2 de 2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Shutter Button Replacement: paso 2, imagen 1 de 2 VTech Kidizoom Camera Connect Shutter Button Replacement: paso 2, imagen 2 de 2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Shutter Button Replacement: paso 3, imagen 1 de 3 VTech Kidizoom Camera Connect Shutter Button Replacement: paso 3, imagen 2 de 3 VTech Kidizoom Camera Connect Shutter Button Replacement: paso 3, imagen 3 de 3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Shutter Button Replacement: paso 4, imagen 1 de 1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
  5. VTech Kidizoom Camera Connect Shutter Button Replacement, Shutter Button: paso 5, imagen 1 de 1
    • Remove the purple plastic that covers the button and circuit board. It should slide right out from the slot it sits in.
  6. VTech Kidizoom Camera Connect Shutter Button Replacement: paso 6, imagen 1 de 1
    • Unsolder wires connected to the right side of the circuit board. Pull the wires to the side.
  7. VTech Kidizoom Camera Connect Shutter Button Replacement: paso 7, imagen 1 de 2 VTech Kidizoom Camera Connect Shutter Button Replacement: paso 7, imagen 2 de 2
    • The button/circuit board should be loose now. Gently pull out the button/circuit board to remove it from the device.
Conclusión
Una persona más ha completado esta guía.
Justin Sanchez
Miembro Desde 02/08/16
493 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 6-4, Eyestone Spring 2016 Miembro de USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 753
