Saltar al contenido principal
VTech Kidizoom Camera Connect Motherboard Replacement
Qué necesitas
  1. VTech Kidizoom Camera Connect Motherboard Replacement, Front Case: paso 1, imagen 1 de 2 VTech Kidizoom Camera Connect Motherboard Replacement, Front Case: paso 1, imagen 2 de 2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Motherboard Replacement: paso 2, imagen 1 de 2 VTech Kidizoom Camera Connect Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Motherboard Replacement: paso 3, imagen 1 de 3 VTech Kidizoom Camera Connect Motherboard Replacement: paso 3, imagen 2 de 3 VTech Kidizoom Camera Connect Motherboard Replacement: paso 3, imagen 3 de 3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Motherboard Replacement: paso 4, imagen 1 de 1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
  5. VTech Kidizoom Camera Connect Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Locate and remove the screws circled in the provided image with a Philips #0 screwdriver.
  6. VTech Kidizoom Camera Connect Motherboard Replacement: paso 6, imagen 1 de 2 VTech Kidizoom Camera Connect Motherboard Replacement: paso 6, imagen 2 de 2
    • Unsolder the connection points on the motherboard.
  7. VTech Kidizoom Camera Connect Motherboard Replacement: paso 7, imagen 1 de 3 VTech Kidizoom Camera Connect Motherboard Replacement: paso 7, imagen 2 de 3 VTech Kidizoom Camera Connect Motherboard Replacement: paso 7, imagen 3 de 3
    • Unsolder the connections to the right battery terminal. Removing the terminal allows easier access to the motherboard.
  8. VTech Kidizoom Camera Connect Motherboard Replacement: paso 8, imagen 1 de 3 VTech Kidizoom Camera Connect Motherboard Replacement: paso 8, imagen 2 de 3 VTech Kidizoom Camera Connect Motherboard Replacement: paso 8, imagen 3 de 3
    • Carefully pull up on the motherboard and pink plastic underneath the motherboard. The pink plastic contains the display and is connected to the motherboard.
Conclusión
5 personas más completaron esta guía.
Justin Sanchez
Miembro Desde 02/08/16
520 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 6-4, Eyestone Spring 2016 Miembro de USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 Miembros
5 Guías creadas
Un comentario
Do you know what the replacement mic is? My girls mic has stopped working. Sound still plays, but can’t record voice or sound for video making. Thanks Tim
Timothy GRAHAM - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 16
Todo El Tiempo: 2,302
