Saltar al contenido principal
VTech Kidizoom Camera Connect Front Case Replacement
Qué necesitas
  1. VTech Kidizoom Camera Connect Front Case Replacement, Front Case: paso 1, imagen 1 de 2 VTech Kidizoom Camera Connect Front Case Replacement, Front Case: paso 1, imagen 2 de 2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Front Case Replacement: paso 2, imagen 1 de 2 VTech Kidizoom Camera Connect Front Case Replacement: paso 2, imagen 2 de 2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Front Case Replacement: paso 3, imagen 1 de 3 VTech Kidizoom Camera Connect Front Case Replacement: paso 3, imagen 2 de 3 VTech Kidizoom Camera Connect Front Case Replacement: paso 3, imagen 3 de 3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Front Case Replacement: paso 4, imagen 1 de 1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
Conclusión
Una persona más ha completado esta guía.
Nick Foster
Miembro Desde 02/14/16
288 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 6-4, Eyestone Spring 2016 Miembro de USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 4,139
