Saltar al contenido principal
VTech Kidizoom Action Cam Speaker Replacement
Qué necesitas
  1. VTech Kidizoom Action Cam Speaker Replacement, Display Assembly: paso 1, imagen 1 de 1
    • Make sure that the master power switch is set to the (O) position.
  2. VTech Kidizoom Action Cam Speaker Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, gently pry off the circular plating over the camera lens.
    • The circular plating is held by a mild adhesive. It will not be necessary to replace this adhesive during the reassembly process.
    • Use a #0 screwdriver to remove the two 2.5mm Phillips head screws located on the second layer of plating.
    • Remove the second layer of plating previously held down by the screws by gripping it with your fingers and pulling upward.
    • As there will be many screws being removed from the device, we recommend using a magnetic device such as the iFixit Magnetic Project Mat.
  3. VTech Kidizoom Action Cam Speaker Replacement: paso 4, imagen 1 de 1
    • Pry off the transparent plating and paper design using a plastic opening tool.
  4. VTech Kidizoom Action Cam Speaker Replacement: paso 5, imagen 1 de 1
    • Unscrew the (4) 2.5mm Phillips head screws from the third layer of plating using a #0 screwdriver.
  5. VTech Kidizoom Action Cam Speaker Replacement: paso 6, imagen 1 de 1
    • Turn the camera around and gently remove the plating that surrounds the LCD screen by grasping it with your fingers and pulling away from the device.
  6. VTech Kidizoom Action Cam Speaker Replacement: paso 7, imagen 1 de 3 VTech Kidizoom Action Cam Speaker Replacement: paso 7, imagen 2 de 3 VTech Kidizoom Action Cam Speaker Replacement: paso 7, imagen 3 de 3
    • Use the plastic opening tool to lift the LCD screen, including the purple casing and set it aside, revealing the motherboard and connector ribbon.
    • Exercise caution while performing this step, as any excessive pulling may tear the connector ribbon from the motherboard.
  7. VTech Kidizoom Action Cam Speaker Replacement, Speaker: paso 8, imagen 1 de 1
    • Use the soldering iron to reheat the solder around the speakers' prongs on the motherboard.
    • Be Careful of very high temperatures when using the soldering iron.
    • The soldering iron may melt the motherboard if contact is made.
  8. VTech Kidizoom Action Cam Speaker Replacement: paso 9, imagen 1 de 1
    • Pry the speaker off the motherboard using a plastic opening tool.
    • Prongs may still be hot from soldering.
Conclusión
Equipo
USF Tampa, Team 3-5, Sullivan Spring 2016 Miembro de USF Tampa, Team 3-5, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G5
3 Miembros
6 Guías creadas
2 comentarios
Hi,
Thanks for the video, was very helpful.
could you pls advice where can I get new speaker or spec for orig one.
my boy was able to destroy it…
Gil - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 282
