Saltar al contenido principal
VTech CS6719-2 Speaker Replacement
Qué necesitas
  1. VTech CS6719-2 Speaker Replacement, Battery: paso 1, imagen 1 de 2 VTech CS6719-2 Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Push down on the battery cover in the direction of the arrow located on the back of the phone.
  2. VTech CS6719-2 Speaker Replacement: paso 2, imagen 1 de 1
    • Pull the battery cover off of the back of the phone.
  3. VTech CS6719-2 Speaker Replacement: paso 3, imagen 1 de 1
    • Unplug the battery input cable.
  4. VTech CS6719-2 Speaker Replacement: paso 4, imagen 1 de 1
    • Lift the battery out of the back of the phone.
  5. VTech CS6719-2 Speaker Replacement, Circuit Board: paso 5, imagen 1 de 2 VTech CS6719-2 Speaker Replacement, Circuit Board: paso 5, imagen 2 de 2
    • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
  6. VTech CS6719-2 Speaker Replacement: paso 6, imagen 1 de 1
    • Use the plastic opening tool and spudger to pry the back side of the phone off.
  7. VTech CS6719-2 Speaker Replacement: paso 7, imagen 1 de 2 VTech CS6719-2 Speaker Replacement: paso 7, imagen 2 de 2
    • Remove the two 9mm screws located inside the back cover at the top.
  8. VTech CS6719-2 Speaker Replacement, Speaker: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Locate the metal shaped U clip holding the speaker on. Pull up and towards the top of the phone with the flat head tweezers.
    • The clip is loose, it could fall out.
  9. VTech CS6719-2 Speaker Replacement: paso 9, imagen 1 de 1
    • Lift speaker out.
  10. VTech CS6719-2 Speaker Replacement: paso 10, imagen 1 de 1
    • Heat up solder joint on the circuit board where the speaker wires are connected.
  11. VTech CS6719-2 Speaker Replacement: paso 11, imagen 1 de 1
    • Refer to How To Solder and Desolder Connections Cómo soldar y desoldar conexiones
    • Note: Ensure the old solder joint is removed.
    • Caution: Soldering iron and joint will become very ho
Conclusión
Benjamin Field
Miembro Desde 02/08/16
270 Reputación
2 Guías creadas
Equipo
IUPUI, Team 1-4, Baechle Spring 2016 Miembro de IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Miembros
16 Guías creadas
2 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 725
