Saltar al contenido principal
VTech CS6719-2 Circuit Board Replacement
Qué necesitas
  1. VTech CS6719-2 Circuit Board Replacement, Battery: paso 1, imagen 1 de 2 VTech CS6719-2 Circuit Board Replacement, Battery: paso 1, imagen 2 de 2
    • Push down on the battery cover in the direction of the arrow located on the back of the phone.
  2. VTech CS6719-2 Circuit Board Replacement: paso 2, imagen 1 de 1
    • Pull the battery cover off of the back of the phone.
  3. VTech CS6719-2 Circuit Board Replacement: paso 3, imagen 1 de 1
    • Unplug the battery input cable.
  4. VTech CS6719-2 Circuit Board Replacement: paso 4, imagen 1 de 1
    • Lift the battery out of the back of the phone.
  5. VTech CS6719-2 Circuit Board Replacement, Circuit Board: paso 5, imagen 1 de 2 VTech CS6719-2 Circuit Board Replacement, Circuit Board: paso 5, imagen 2 de 2
    • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
  6. VTech CS6719-2 Circuit Board Replacement: paso 6, imagen 1 de 1
    • Use the plastic opening tool and spudger to pry the back side of the phone off.
  7. VTech CS6719-2 Circuit Board Replacement: paso 7, imagen 1 de 2 VTech CS6719-2 Circuit Board Replacement: paso 7, imagen 2 de 2
    • Remove the two 9mm screws located inside the back cover at the top.
Conclusión
3 personas más completaron esta guía.
Benjamin Field
Miembro Desde 02/08/16
270 Reputación
2 Guías creadas
Equipo
IUPUI, Team 1-4, Baechle Spring 2016 Miembro de IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Miembros
16 Guías creadas
Un comentario
Thanks! Had to clean honey out if the speaker. Should Note the plastic quality is soft and can mark easily.
Jason Bellchamber - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 503
