Introducción
During this guide, the base will need to be disassembled and then desolder the charging wire connections.
Qué necesitas
Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
Una persona más ha completado esta guía.
