Saltar al contenido principal
VTech CS6719-2 Charging Wire Repair
Qué necesitas
  1. VTech CS6719-2 Charging Wire Repair, Base: paso 1, imagen 1 de 2 VTech CS6719-2 Charging Wire Repair, Base: paso 1, imagen 2 de 2
    • Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
  2. VTech CS6719-2 Charging Wire Repair: paso 2, imagen 1 de 1
    • Use the spudger to separate the bottom from the top.
    • There are two clips, located top and bottom, that you have to compress with the spudger.
  3. VTech CS6719-2 Charging Wire Repair, Charging Wire: paso 3, imagen 1 de 1
    • Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
  4. VTech CS6719-2 Charging Wire Repair: paso 4, imagen 1 de 1
    • Refer to How to Solder and Desolder connections Cómo soldar y desoldar conexiones
    • Note: Ensure the old solder joint is removed.
    • Caution: Soldering iron and joint will become very hot.
  5. VTech CS6719-2 Charging Wire Repair: paso 5, imagen 1 de 1
    • Heat up solder joint on the base unit where the charging wires are connected.
  6. VTech CS6719-2 Charging Wire Repair: paso 6, imagen 1 de 1
    • Take a wire of solder and apply to joint on board to remove the extra solder.
    • Remove charging wire connection.
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team 1-4, Baechle Spring 2016 Miembro de IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 1,379
