Saltar al contenido principal
VEX V5 11w smart motor Un-seizing
Qué necesitas
  1. VEX V5 11w smart motor Un-seizing, remove top case and gear cartridge: paso 1, imagen 1 de 1
    • use a Small Phillips head screwdriver to remove the top case.
    • simply pull the cartridge out of the motor.
    • NOTE: my motor had no case when I got it so I only had the attached PDF for images.
  2. VEX V5 11w smart motor Un-seizing, remove main case: paso 2, imagen 1 de 3 VEX V5 11w smart motor Un-seizing, remove main case: paso 2, imagen 2 de 3 VEX V5 11w smart motor Un-seizing, remove main case: paso 2, imagen 3 de 3
    • Remove the 4 screws holding the top case on the motor.
    • Once the screws are removed you can pull the 2 pieces apart.
  3. VEX V5 11w smart motor Un-seizing, remove bottom gear cover: paso 3, imagen 1 de 3 VEX V5 11w smart motor Un-seizing, remove bottom gear cover: paso 3, imagen 2 de 3 VEX V5 11w smart motor Un-seizing, remove bottom gear cover: paso 3, imagen 3 de 3
    • Remove the 2 Phillips head screws holding the bottom case on.
    • Pull the bottom case off.
  4. VEX V5 11w smart motor Un-seizing, remove center gear: paso 4, imagen 1 de 2 VEX V5 11w smart motor Un-seizing, remove center gear: paso 4, imagen 2 de 2
    • Use your fingers, a small flathead screwdriver, or a spudger to remove the center gear.
  5. VEX V5 11w smart motor Un-seizing, tap and twist the motor shaft: paso 5, imagen 1 de 3 VEX V5 11w smart motor Un-seizing, tap and twist the motor shaft: paso 5, imagen 2 de 3 VEX V5 11w smart motor Un-seizing, tap and twist the motor shaft: paso 5, imagen 3 de 3
    • 1. Tap the small metal gear and metal shaft on the other side of the motor.
    • 2. Grip the metal gear with pliers and twist 1 full revolution or until the motor spins freely by hand.
Conclusión
Documentos Adjuntos
Austin Walter
Miembro Desde 01/16/23
1,025 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 133
