Saltar al contenido principal
VEX Robotics VEX EDR 393 Gear Replacement
Qué necesitas
  1. VEX Robotics VEX EDR 393 Gear Replacement, Motor Gears: paso 1, imagen 1 de 1
    • Disconnect the motor from any other connected devices or power sources.
    • Use a Small Phillips Head Screwdriver to unscrew the four screws from the black casing's corners.
  2. VEX Robotics VEX EDR 393 Gear Replacement: paso 2, imagen 1 de 1
    • Pull off the black bottom casing.
    • Remove the two gears inside.
  3. VEX Robotics VEX EDR 393 Gear Replacement: paso 3, imagen 1 de 2 VEX Robotics VEX EDR 393 Gear Replacement: paso 3, imagen 2 de 2
    • Select the replacement gears that match the gears you just removed.
    • Take the gear that has teeth on its entire length and insert it onto the metal pin. Push it all the way into the bottom of the motor. It should connect with a small gear on the bottom.
    • Now, insert the larger gear with teeth on the base onto the circular plastic peg.
    • Make sure the gears are aligned. Spin the top gear with your fingers a few times to double check.
    • Replace the black bottom casing and screws.
    • The screws are susceptible to stripping so do not over-tighten them.
  4. VEX Robotics VEX EDR 393 Gear Replacement: paso 4, imagen 1 de 1
    • Use a Small Phillips Head Screwdriver to unscrew the four screws from the green casing's corners.
  5. VEX Robotics VEX EDR 393 Gear Replacement: paso 5, imagen 1 de 2 VEX Robotics VEX EDR 393 Gear Replacement: paso 5, imagen 2 de 2
    • Pull off the green top casing.
    • The small gear on the left is attached to the motor module itself and cannot be removed.
  6. VEX Robotics VEX EDR 393 Gear Replacement: paso 6, imagen 1 de 3 VEX Robotics VEX EDR 393 Gear Replacement: paso 6, imagen 2 de 3 VEX Robotics VEX EDR 393 Gear Replacement: paso 6, imagen 3 de 3
    • Replace the old stripped gears with the remaining replacement gears.
    • Place the gear with the long stem into the larger gap.
    • Make sure it catches on the gear at the bottom.
    • Place the smaller gear into the motor.
    • Make sure that it catches on both the tiny gear attached to the motor and the long stem gear.
  7. VEX Robotics VEX EDR 393 Gear Replacement: paso 7, imagen 1 de 1
    • Replace the green top casing.
    • Ensure the casing fits between the ridges on the wires' rubber collar.
    • Use a Small Phillips Head Screwdriver to replace the four screws.
Conclusión
Your motor should be working again. Before reinstalling it on your robot, test it either with a backup battery or by plugging it in to your cortex. If you hear more grinding or anything out of the ordinary, reopen the motor to make sure the gears are aligned.
You can also use this process to change the gear ratio of the motor for different functions.
Una persona más ha completado esta guía.
Colin McInerney
Miembro Desde 05/31/16
101 Reputación
1 Guía escrita
Un comentario
does anyone sell repair kits from broken off wires. I have 30 motors with wires torn off (because of the 100 students)
Bob Hankinson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 1,416
