Introducción
Here we will be removing the small michrophone in the back of the taco. This task requires removing the logic board before it may be reached.
Qué necesitas
Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
Below the logic board, the small black microphone is resting within the case.
Una persona más ha completado esta guía.
