Saltar al contenido principal
VENSTAR Taco Logic Board Replacement Replacement
Qué necesitas
  1. VENSTAR Taco Logic Board Replacement Replacement, VENSTAR Taco Disassembly: paso 1, imagen 1 de 3 VENSTAR Taco Logic Board Replacement Replacement, VENSTAR Taco Disassembly: paso 1, imagen 2 de 3 VENSTAR Taco Logic Board Replacement Replacement, VENSTAR Taco Disassembly: paso 1, imagen 3 de 3
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
  2. VENSTAR Taco Logic Board Replacement Replacement: paso 2, imagen 1 de 2 VENSTAR Taco Logic Board Replacement Replacement: paso 2, imagen 2 de 2
    • Repeat the previous step on the opposite side to remove the other outer casing.
  3. VENSTAR Taco Logic Board Replacement Replacement: paso 3, imagen 1 de 2 VENSTAR Taco Logic Board Replacement Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Phillips #0 Screwdriver
    $5.49
    Comprar
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
  4. VENSTAR Taco Logic Board Replacement Replacement: paso 4, imagen 1 de 2 VENSTAR Taco Logic Board Replacement Replacement: paso 4, imagen 2 de 2
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
  5. VENSTAR Taco Logic Board Replacement Replacement: paso 5, imagen 1 de 2 VENSTAR Taco Logic Board Replacement Replacement: paso 5, imagen 2 de 2
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
  6. VENSTAR Taco Logic Board Replacement Replacement, Logic Board Replacement: paso 6, imagen 1 de 1
    • Remove the rubber covering from the buttons.
  7. VENSTAR Taco Logic Board Replacement Replacement: paso 7, imagen 1 de 3 VENSTAR Taco Logic Board Replacement Replacement: paso 7, imagen 2 de 3 VENSTAR Taco Logic Board Replacement Replacement: paso 7, imagen 3 de 3
    • Remove the black fabric covering the logic board.
  8. VENSTAR Taco Logic Board Replacement Replacement: paso 8, imagen 1 de 2 VENSTAR Taco Logic Board Replacement Replacement: paso 8, imagen 2 de 2
    • Move the battery out of the way of the connector.
  9. VENSTAR Taco Logic Board Replacement Replacement: paso 9, imagen 1 de 2 VENSTAR Taco Logic Board Replacement Replacement: paso 9, imagen 2 de 2
    • Undo the connector of the flat white ribbon between the switches and the logic board.
  10. VENSTAR Taco Logic Board Replacement Replacement: paso 10, imagen 1 de 1
    • Undo the two black 3mm screws on the logic board using the PH0 screwdriver.
  11. VENSTAR Taco Logic Board Replacement Replacement: paso 11, imagen 1 de 3 VENSTAR Taco Logic Board Replacement Replacement: paso 11, imagen 2 de 3 VENSTAR Taco Logic Board Replacement Replacement: paso 11, imagen 3 de 3
    • Gently pull out the logic board.
    • Note that the battery and the logic board are connected and must be removed together.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 295
