Introducción
There is no visible way to open this device. Knowing this, assembly and disassembly must be done carefully in order to maintain the integrity of the device.
Qué necesitas
Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
Herramienta utilizada en este paso:Phillips #0 Screwdriver$5.49
Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
Casi Terminas!
Conclusión
