Saltar al contenido principal
Peligro
Potencialmente Peligroso
Una lesión puede resultar si este procedimiento no se sigue correctamente. Ten precaución y sigue todas las advertencias.
Peligro
Introducción
To lift the car, use a Hydraulic Jack. Keeping a car propped up for long periods may cause harm to the car. For safety, use Jacks stands so the car will not fall while you work.
Herramientas
Partes
No se especificaron partes.
  1. Identify the jack point, located directly underneath your car, in the center portion between the front two wheels. Place the Hydraulic Jack beneath the jack point.
    • Identify the jack point, located directly underneath your car, in the center portion between the front two wheels.
    • Place the Hydraulic Jack beneath the jack point.
    • Pump the lever on the Hydraulic Jack, up and down, until the jack makes contact with the jack point. (Adjust the placement if necessary).
    • Continue pumping the lever until the wheels are two inches off the ground.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Identify the jack points located behind each front tire. Place a Jack Stand underneath both jack points. Clear the area underneath the car of people or debris. Make sure the jack stands are properly supporting the car.
    • Identify the jack points located behind each front tire. Place a Jack Stand underneath both jack points.
    • Clear the area underneath the car of people or debris. Make sure the jack stands are properly supporting the car.
    • Slowly rotate the Hydraulic Jack counter-clockwise to lower it. (Half a turn should be enough.)
    • After fully lowering the Hydraulic Jack, remove it from underneath your car.
Conclusión
To remove jack stands, follow guide in reverse order, remembering that lowering and raising the Pneumatic Jack require different actions.
Matt Ondriezek
Miembro Desde 14/04/14
462 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 12-35, Maness Spring 2014 Miembro de Cal Poly, Team 12-35, Maness Spring 2014
CPSU-MANESS-S14S12G35
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 5
Últimos 30 Días: 33
Todo El Tiempo: 871
