Saltar al contenido principal
Urge Basics Soundbrick Speaker Woofer Replacement
Qué necesitas
  1. Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: paso 1, imagen 1 de 3 Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: paso 1, imagen 2 de 3 Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: paso 1, imagen 3 de 3
    • Flip the speaker upside down.
    • Unscrew the middle screw with a Philips #1 screwdriver.
  2. Urge Basics Soundbrick Speaker Woofer Replacement: paso 2, imagen 1 de 2 Urge Basics Soundbrick Speaker Woofer Replacement: paso 2, imagen 2 de 2
    • Peel off the two gray tabs to expose the four inner Philips #1 screws.
  3. Urge Basics Soundbrick Speaker Woofer Replacement: paso 3, imagen 1 de 3 Urge Basics Soundbrick Speaker Woofer Replacement: paso 3, imagen 2 de 3 Urge Basics Soundbrick Speaker Woofer Replacement: paso 3, imagen 3 de 3
    • Unscrew all four screws with a Philips #1 screwdriver.
    • The screws are deep and can be difficult to take out.
  4. Urge Basics Soundbrick Speaker Woofer Replacement: paso 4, imagen 1 de 3 Urge Basics Soundbrick Speaker Woofer Replacement: paso 4, imagen 2 de 3 Urge Basics Soundbrick Speaker Woofer Replacement: paso 4, imagen 3 de 3
    • Flip the speaker so that the ports are facing up.
    • Unfold the speaker's cover away from the body.
  5. Urge Basics Soundbrick Speaker Woofer Replacement: paso 5, imagen 1 de 2 Urge Basics Soundbrick Speaker Woofer Replacement: paso 5, imagen 2 de 2
    • Remove the two Phillips #1 screws found on each side of the battery compartment.
    • Removal of battery compartment is necessary to prevent electric shock when replacing the woofer.
  6. Urge Basics Soundbrick Speaker Woofer Replacement: paso 6, imagen 1 de 3 Urge Basics Soundbrick Speaker Woofer Replacement: paso 6, imagen 2 de 3 Urge Basics Soundbrick Speaker Woofer Replacement: paso 6, imagen 3 de 3
    • Disconnect the battery connectors attached to the circuit board by unplugging them.
  7. Urge Basics Soundbrick Speaker Woofer Replacement: paso 7, imagen 1 de 3 Urge Basics Soundbrick Speaker Woofer Replacement: paso 7, imagen 2 de 3 Urge Basics Soundbrick Speaker Woofer Replacement: paso 7, imagen 3 de 3
    • Disconnect the ribbon cable from the battery by carefully pulling it out.
    • Remove the battery compartment.
  8. Urge Basics Soundbrick Speaker Woofer Replacement: paso 8, imagen 1 de 3 Urge Basics Soundbrick Speaker Woofer Replacement: paso 8, imagen 2 de 3 Urge Basics Soundbrick Speaker Woofer Replacement: paso 8, imagen 3 de 3
    • Disconnect the adjacent connector from the main circuit board.
  9. Urge Basics Soundbrick Speaker Woofer Replacement: paso 9, imagen 1 de 3 Urge Basics Soundbrick Speaker Woofer Replacement: paso 9, imagen 2 de 3 Urge Basics Soundbrick Speaker Woofer Replacement: paso 9, imagen 3 de 3
    • Disconnect the woofer's two connectors from the main circuit board.
  10. Urge Basics Soundbrick Speaker Woofer Replacement: paso 10, imagen 1 de 3 Urge Basics Soundbrick Speaker Woofer Replacement: paso 10, imagen 2 de 3 Urge Basics Soundbrick Speaker Woofer Replacement: paso 10, imagen 3 de 3
    • Remove the two Phillips #1 screws keeping each woofer in place.
    • Carefully remove the woofers and replace them with new ones.
Conclusión
Una persona más ha completado esta guía.
Itzel Urueta
Miembro Desde 04/28/17
125 Reputación
1 Guía escrita
Equipo
UC Davis, Team S2-G4, Cole Spring 2017 Miembro de UC Davis, Team S2-G4, Cole Spring 2017
UCD-COLE-S17S2G4
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 877
