Saltar al contenido principal
Unnecto Drone M Headphone Jack Replacement
Qué necesitas
  1. Unnecto Drone M Headphone Jack Replacement, Unnecto Drone M Disassembly: paso 1, imagen 1 de 2 Unnecto Drone M Headphone Jack Replacement, Unnecto Drone M Disassembly: paso 1, imagen 2 de 2
    • Place the phone facedown on a cleared work area
    • Remove the back case by applying moderate force to the indentation in the lower left corner of the case.
  2. Unnecto Drone M Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Grip the top right corner of the battery.
    • Remove the battery by pulling it outwards.
  3. Unnecto Drone M Headphone Jack Replacement: paso 3, imagen 1 de 1
    • Remove the four screws on the back of the phone using a Philips 000 screwdriver
  4. Unnecto Drone M Headphone Jack Replacement: paso 4, imagen 1 de 1
    • Separate the frame evenly using a plastic opening tool.
    • Be careful, as the frame is thin and can break easily.
  5. Unnecto Drone M Headphone Jack Replacement: paso 5, imagen 1 de 2 Unnecto Drone M Headphone Jack Replacement: paso 5, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard.
  6. Unnecto Drone M Headphone Jack Replacement: paso 6, imagen 1 de 1
    • Disconnect the ribbon cable from the motherboard using rounded, spade-tipped tweezers.
  7. Unnecto Drone M Headphone Jack Replacement: paso 7, imagen 1 de 1
    • Peel the white circuit on left side of the frame by inserting fine-tipped tweezers between it and the frame.
    • The white circuit is flimsy and securely glued to the frame.
  8. Unnecto Drone M Headphone Jack Replacement: paso 8, imagen 1 de 2 Unnecto Drone M Headphone Jack Replacement: paso 8, imagen 2 de 2
    • Set aside the circuit board from the screen protector.
  9. Unnecto Drone M Headphone Jack Replacement, Headphone Jack: paso 9, imagen 1 de 3 Unnecto Drone M Headphone Jack Replacement, Headphone Jack: paso 9, imagen 2 de 3 Unnecto Drone M Headphone Jack Replacement, Headphone Jack: paso 9, imagen 3 de 3
    • Desolder the headphone jack using a soldering iron on each of the 6 points holding it down.
    • Be careful to not damage the circuit board.
  10. Unnecto Drone M Headphone Jack Replacement: paso 10, imagen 1 de 2 Unnecto Drone M Headphone Jack Replacement: paso 10, imagen 2 de 2
    • Solder on a new headphone jack.
  11. Unnecto Drone M Headphone Jack Replacement: paso 11, imagen 1 de 1
    • Make sure the new jack is aligned properly and securely soldered to the circuit board.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 11
Todo El Tiempo: 180
