Saltar al contenido principal
Uniden UTAB71 Speaker Replacement
Qué necesitas
  1. Uniden UTAB71 Speaker Replacement, Speaker: paso 1, imagen 1 de 2 Uniden UTAB71 Speaker Replacement, Speaker: paso 1, imagen 2 de 2
    • Use a plastic pry tool to undo the clips that attach the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Speaker Replacement: paso 2, imagen 1 de 1
    • Use a soldering tool to disconnect the speaker wires off the motherboard.
    • If you have no experience in soldering, please follow this guide
Conclusión
Ryan Jewell
Miembro Desde 10/20/16
422 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 5-4, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 163
