Saltar al contenido principal
Uniden UTAB71 Screen Replacement
Qué necesitas
  1. Uniden UTAB71 Screen Replacement, Screen: paso 1, imagen 1 de 2 Uniden UTAB71 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Use a pry tool to undo the clips that attach the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Screen Replacement: paso 2, imagen 1 de 2 Uniden UTAB71 Screen Replacement: paso 2, imagen 2 de 2
    • Lift off the black clip connecting the first power ribbon to the motherboard
    • Undo the clips off the second power ribbon connecting the screen to the motherboard.
  3. Uniden UTAB71 Screen Replacement: paso 3, imagen 1 de 3 Uniden UTAB71 Screen Replacement: paso 3, imagen 2 de 3 Uniden UTAB71 Screen Replacement: paso 3, imagen 3 de 3
    • Slowly remove the screen component off the tablet by clipping the screen from the tablet outine
    • Do not apply too much pressure on the tablet casing.
Conclusión
Una persona más ha completado esta guía.
Ryan Jewell
Miembro Desde 10/20/16
422 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 5-4, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 343
