Saltar al contenido principal
Uniden UTAB71 Camera Replacement
Qué necesitas
  1. Uniden UTAB71 Camera Replacement, Camera: paso 1, imagen 1 de 2 Uniden UTAB71 Camera Replacement, Camera: paso 1, imagen 2 de 2
    • Use a plastic pry tool to separate the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Camera Replacement: paso 2, imagen 1 de 2 Uniden UTAB71 Camera Replacement: paso 2, imagen 2 de 2
    • Use a credit card to lift the battery off the back of the tablet.
    • Do not put any pressure on the motherboard or any other internal components.
    • The battery is glued onto the back of the tablet so make sure to apply as much pressure as needed
  3. Uniden UTAB71 Camera Replacement: paso 3, imagen 1 de 1
    • Undo the clips off the power ribbon connecting the camera to the motherboard using the blue pry tool.
  4. Uniden UTAB71 Camera Replacement: paso 4, imagen 1 de 3 Uniden UTAB71 Camera Replacement: paso 4, imagen 2 de 3 Uniden UTAB71 Camera Replacement: paso 4, imagen 3 de 3
    • Use the pry tool to remove the yellow tape from the power ribbon connected to the camera.
    • Place the plastic pry tool under the camera component and lift it off the tablet.
Conclusión
Ryan Jewell
Miembro Desde 10/20/16
422 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 5-4, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 170
