Saltar al contenido principal
Uniden UTAB71 Battery Replacement
Qué necesitas
  1. Uniden UTAB71 Battery Replacement, Battery: paso 1, imagen 1 de 2 Uniden UTAB71 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Use a plastic opening tool to undo the clips that attach the two halves of the tablet.
    • Be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Battery Replacement: paso 2, imagen 1 de 1
    • Lift off the tape that holds the speaker wires to the battery
    • Leave the tape off to the side
  3. Uniden UTAB71 Battery Replacement: paso 3, imagen 1 de 1
    • Use a soldering tool to disconnect the two wires (red and black) that connect the battery to the motherboard
    • Note the placement of each colored wire in the motherboard
    • If you have no experience in soldering, please follow this guide
  4. Uniden UTAB71 Battery Replacement: paso 4, imagen 1 de 2 Uniden UTAB71 Battery Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    iOpener
    $12.99
    Comprar
    • Use a credit card to lift the battery off the back of the tablet
    • Do not put any pressure on the motherboard or any other internal components.
    • The battery attached to the back panel with adhesive. You may need to use a heated iOpener to loosen the adhesive and remove the battery.
Conclusión
Ryan Jewell
Miembro Desde 10/20/16
422 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 5-4, Martin Fall 2016 Miembro de UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 346
