Saltar al contenido principal
Uniden TCX905 Home Button Replacement
Qué necesitas
  1. Uniden TCX905 Home Button Replacement, Battery Cover: paso 1, imagen 1 de 2 Uniden TCX905 Home Button Replacement, Battery Cover: paso 1, imagen 2 de 2
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
  2. Uniden TCX905 Home Button Replacement, Battery Pack: paso 2, imagen 1 de 2 Uniden TCX905 Home Button Replacement, Battery Pack: paso 2, imagen 2 de 2
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
  3. Uniden TCX905 Home Button Replacement, Back Shell: paso 3, imagen 1 de 2 Uniden TCX905 Home Button Replacement, Back Shell: paso 3, imagen 2 de 2
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
  4. Uniden TCX905 Home Button Replacement: paso 4, imagen 1 de 3 Uniden TCX905 Home Button Replacement: paso 4, imagen 2 de 3 Uniden TCX905 Home Button Replacement: paso 4, imagen 3 de 3
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
  5. Uniden TCX905 Home Button Replacement: paso 5, imagen 1 de 3 Uniden TCX905 Home Button Replacement: paso 5, imagen 2 de 3 Uniden TCX905 Home Button Replacement: paso 5, imagen 3 de 3
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
  6. Uniden TCX905 Home Button Replacement, Circuit Board: paso 6, imagen 1 de 2 Uniden TCX905 Home Button Replacement, Circuit Board: paso 6, imagen 2 de 2
    • Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
  7. Uniden TCX905 Home Button Replacement: paso 7, imagen 1 de 3 Uniden TCX905 Home Button Replacement: paso 7, imagen 2 de 3 Uniden TCX905 Home Button Replacement: paso 7, imagen 3 de 3
    • Using index finger and thumb, carefully remove the circuit board from the front shell of phone
  8. Uniden TCX905 Home Button Replacement, Home Button: paso 8, imagen 1 de 3 Uniden TCX905 Home Button Replacement, Home Button: paso 8, imagen 2 de 3 Uniden TCX905 Home Button Replacement, Home Button: paso 8, imagen 3 de 3
    • Remove the white plastic sheet covering the silicon button pad
    • Remove the silicon button pad to access the home button and spring
    • Note: Be mindful that the spring is small and sensitive and can be lost easily if not cautious
  9. Uniden TCX905 Home Button Replacement: paso 9, imagen 1 de 2 Uniden TCX905 Home Button Replacement: paso 9, imagen 2 de 2
    • Once the silicon button pad is removed, remove the spring from home button
    • Finally, remove the home button from its setting in the front shell of the phone
Conclusión
Gary Pence
Miembro Desde 03/26/14
807 Reputación
8 Guías creadas
Equipo
Clemson, Team 1-1, Benson Spring 2014 Miembro de Clemson, Team 1-1, Benson Spring 2014
CLEM-BENSON-S14S1G1
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 592
