Saltar al contenido principal
Uniden EXP 371 Handset Casing Replacement
Qué necesitas
  1. Uniden EXP 371 Handset Casing Replacement, Uniden EXP 371 Teardown: paso 1, imagen 1 de 1
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Uniden EXP 371 Handset Casing Replacement: paso 2, imagen 1 de 2 Uniden EXP 371 Handset Casing Replacement: paso 2, imagen 2 de 2
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. Uniden EXP 371 Handset Casing Replacement: paso 3, imagen 1 de 2 Uniden EXP 371 Handset Casing Replacement: paso 3, imagen 2 de 2
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  4. Uniden EXP 371 Handset Casing Replacement: paso 4, imagen 1 de 3 Uniden EXP 371 Handset Casing Replacement: paso 4, imagen 2 de 3 Uniden EXP 371 Handset Casing Replacement: paso 4, imagen 3 de 3
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
  5. Uniden EXP 371 Handset Casing Replacement, Handset Casing: paso 5, imagen 1 de 1
    • You must remove the speakers in order to replace the front casing of the phone. Use the #1 philips screwdriver.
    • Once the phone is completely disassembled follow the steps in the reverse order using the new phone case to reassemble your phone.
Conclusión
Ethan DiTullio
Miembro Desde 10/17/14
125 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 2-1, Duarte Fall 2014 Miembro de UMass Dartmouth, Team 2-1, Duarte Fall 2014
UMASSD-DUARTE-F14S2G1
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 128
