Saltar al contenido principal
Uniden EXP 371 Charging Contact Points Replacement
Qué necesitas
  1. Uniden EXP 371 Charging Contact Points Replacement, Charging Contact Points: paso 1, imagen 1 de 2 Uniden EXP 371 Charging Contact Points Replacement, Charging Contact Points: paso 1, imagen 2 de 2
    • Your first step will be to remove the battery cover and the battery.
  2. Uniden EXP 371 Charging Contact Points Replacement: paso 2, imagen 1 de 1
    • The next step will be to remove the two screws from the rear of the phone case.
  3. Uniden EXP 371 Charging Contact Points Replacement: paso 3, imagen 1 de 1
    • After that you will need to pry the back of the case off of the front part of the case.
  4. Uniden EXP 371 Charging Contact Points Replacement: paso 4, imagen 1 de 2 Uniden EXP 371 Charging Contact Points Replacement: paso 4, imagen 2 de 2
    • After removing the rear cover there will be two more screws to remove that hold each of the charging contact points. Once those are removed you can replace them with the new ones.
    • When replacing the charging contacts, they only go on one way, but it is useful to note how the original ones were on.
    • Reverse these steps in order to reassemble your phone.
Conclusión
Eric Rodrigues
Miembro Desde 10/16/14
343 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 2-1, Duarte Fall 2014 Miembro de UMass Dartmouth, Team 2-1, Duarte Fall 2014
UMASSD-DUARTE-F14S2G1
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 143
