Saltar al contenido principal
Uniden EXP 371 Battery Replacement
  1. Uniden EXP 371 Battery Replacement, Battery Cover: paso 1, imagen 1 de 1
    • To remove the battery cover, push in and downwards towards yourself on the cover. There is a notch on the back that you can use to get a better grip if necessary.
  2. Uniden EXP 371 Battery Replacement: paso 2, imagen 1 de 1
    • Pull the battery away from the battery housing. At the end of the wires on the housing side there is a clip that connects the battery to the phone. Unplug this clip and discard the warn battery appropriately.
  3. Uniden EXP 371 Battery Replacement: paso 3, imagen 1 de 1
    • Now take your new battery pack and insert the new plug into the housing. The plug should smoothly clip right into the phone.
    • If the clip does not fit easily into the housing, compare the new battery with the old and be sure they are the same.
  4. Uniden EXP 371 Battery Replacement, Replace Battery: paso 4, imagen 1 de 1
    • Push the wires back into the housing to allow the battery to fit under the battery cover.
    • Put the cover back on. Listen for a click, which will indicate the cover is placed correctly.
Conclusión
Eric Rodrigues
Miembro Desde 10/16/14
343 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 2-1, Duarte Fall 2014 Miembro de UMass Dartmouth, Team 2-1, Duarte Fall 2014
UMASSD-DUARTE-F14S2G1
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 12
Todo El Tiempo: 166
