Introducción
This guide shows you how to replace the display on a Uniden Dect 6.0 home phone. Use this guide if you have a poor quality display or no display at all on the phone’s LED screen.
Make sure the screen isn’t faulty due to the battery before moving on. Check the Uniden Dect 6.0 Troubleshooting page for more information.
Qué necesitas
Locate the battery compartment on the back of the Uniden home phone.
Place your finger on the groove, and pull directly back on the cover to access to the battery.
Using a Phillips #1 screwdriver, remove the two .9 mm screws on the back of the device on each side of the battery pack.
To better access the screen, remove the loose gel casing that sits under the keyboard.
3 personas más completaron esta guía.
