Introducción
We are going to teach you how to remove the top shell circuit board. By removing this, you will learn how to use the spudger to get into very tight spots. Also you will know how to remove the ribbon.
Qué necesitas
Unplug the phone from the base by detaching the RJ-11 plug.
Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
Unscrew the 3 screws(Head Size: 4mm Length: 8.6 mm) from the top shell circuit board.
