Saltar al contenido principal
Uniden D1688 Base Replacement
Qué necesitas
  1. Uniden D1688 Base Replacement, Uniden D1688 Base Replacement: paso 1, imagen 1 de 1
    • Unplug the phone from the base by detaching the RJ-11 plug.
    • Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
  2. Uniden D1688 Base Replacement: paso 2, imagen 1 de 2 Uniden D1688 Base Replacement: paso 2, imagen 2 de 2
    • Using the spudger, separate the top shell of the base from the bottom shell from the base.
    • Use care when separating the base so the ribbon cable between the top shell circuit board and the bottom shell circuit board is not damaged!
    • Lift the top shell off the bottom, and you have successfully opened the phone base.
Conclusión
Una persona más ha completado esta guía.
justin
Miembro Desde 01/26/15
419 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 284
