Saltar al contenido principal
Uniden D1685 front panel and keypad replacement
Qué necesitas
  1. Uniden D1685 front panel and keypad replacement, Front Panel and Keypad: paso 1, imagen 1 de 1
    • Turn the phone over with the back facing upwards.
  2. Uniden D1685 front panel and keypad replacement: paso 2, imagen 1 de 1
    • Press your thumb down on the top of the cover and push downwards.
  3. Uniden D1685 front panel and keypad replacement: paso 3, imagen 1 de 1
    • Once removed the battery will be connected by 2 wires.
    • Do not pull the red and black wires.
  4. Uniden D1685 front panel and keypad replacement: paso 4, imagen 1 de 1
    • Pull the small, grey connector that is connected to the phone to disconnect the battery pack.
  5. Uniden D1685 front panel and keypad replacement: paso 5, imagen 1 de 2 Uniden D1685 front panel and keypad replacement: paso 5, imagen 2 de 2
    • Remove the two 3.175 mm screws with the small Phillips head (PH1) screwdriver on the bottom of the phone next to where the battery was removed.
  6. Uniden D1685 front panel and keypad replacement: paso 6, imagen 1 de 2 Uniden D1685 front panel and keypad replacement: paso 6, imagen 2 de 2
    • Once removed, use plastic opening tool to pull the back and front apart in 3 different locations; the bottom and both sides.
  7. Uniden D1685 front panel and keypad replacement: paso 7, imagen 1 de 1
    • After splitting the phone there will be 2 wires that connect the phone's circuit board with the speaker on the back.
  8. Uniden D1685 front panel and keypad replacement: paso 8, imagen 1 de 1
    • The circuit board (Large Green) is attached by 1 3.175mm screw in the top, left corner.
    • Remove this screw using a small Phillips head screwdriver (PH!) from the iFixit toolkit.
  9. Uniden D1685 front panel and keypad replacement: paso 9, imagen 1 de 1
    • Once the screw has been removed, the circuit board will be removable.
    • Gently remove the circuit board and place it on the back of the phone.
  10. Uniden D1685 front panel and keypad replacement: paso 10, imagen 1 de 2 Uniden D1685 front panel and keypad replacement: paso 10, imagen 2 de 2
    • The keyboard will now be accessible. Remove the Bumper Pad (rubber pad behind actual keypad).
    • Remove the keypad.
  11. Uniden D1685 front panel and keypad replacement: paso 11, imagen 1 de 2 Uniden D1685 front panel and keypad replacement: paso 11, imagen 2 de 2
    • Clean the pad with cleaning spray and/or a brush.
  12. Uniden D1685 front panel and keypad replacement: paso 12, imagen 1 de 1
    • Once cleaned, make sure to dry off all of the components entirely.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Did all of the above but I can’t get the center piece to work! I have no volume control and I can’t access anything like phone numbers, etc.
Honda Dude - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 343
