Saltar al contenido principal
Uniden D1483-3BK Handset Keypad Replacement
Qué necesitas
  1. Uniden D1483-3BK Handset Keypad Replacement, Battery: paso 1, imagen 1 de 1
    • Set the phone with dial keys facing downward.
  2. Uniden D1483-3BK Handset Keypad Replacement: paso 2, imagen 1 de 2 Uniden D1483-3BK Handset Keypad Replacement: paso 2, imagen 2 de 2
    • Slide the battery cover toward the bottom of the phone.
    • Lift and remove the back cover from the phone.
  3. Uniden D1483-3BK Handset Keypad Replacement: paso 3, imagen 1 de 1
    • Remove the battery from its compartment.
    • Pinch the end of cord where the battery is attached to the phone and pull up gently.
  4. Uniden D1483-3BK Handset Keypad Replacement, Handset Case: paso 4, imagen 1 de 2 Uniden D1483-3BK Handset Keypad Replacement, Handset Case: paso 4, imagen 2 de 2
    • Remove the two 9mm Phillips #1 screws in the battery compartment.
  5. Uniden D1483-3BK Handset Keypad Replacement: paso 5, imagen 1 de 3 Uniden D1483-3BK Handset Keypad Replacement: paso 5, imagen 2 de 3 Uniden D1483-3BK Handset Keypad Replacement: paso 5, imagen 3 de 3
    • Use the plastic opening tool to carefully separate the two halves of the case.
    • Slowly work around the entire case to fully separate the halves before pulling them apart.
    • Wires inside the case hold the two halves together, tearing these wires will lead to a need for additional repair.
  6. Uniden D1483-3BK Handset Keypad Replacement: paso 6, imagen 1 de 2 Uniden D1483-3BK Handset Keypad Replacement: paso 6, imagen 2 de 2
    • Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
  7. Uniden D1483-3BK Handset Keypad Replacement: paso 7, imagen 1 de 2 Uniden D1483-3BK Handset Keypad Replacement: paso 7, imagen 2 de 2
    • Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
    • Set the board in the lower half of the case.
  8. Uniden D1483-3BK Handset Keypad Replacement, Handset Keypad: paso 8, imagen 1 de 1
    • Remove the rubber keypad from the front half of the handset case.
    • The keypad comes in two separate pieces.
Conclusión
6 personas más completaron esta guía.
Arbitrary Name
Miembro Desde 01/28/15
1,083 Reputación
4 Guías creadas
Equipo
Penn State, Team 1-8, Kaschak Winter 2015 Miembro de Penn State, Team 1-8, Kaschak Winter 2015
PSU-KASCHAK-W15S1G8
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 209
