Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Follow this guide to replace the handset battery. This guide is easy to complete and does not take much time. Removing the battery will also help you to access other parts of the device.
  1. Set the phone with dial keys facing downward.
    • Set the phone with dial keys facing downward.
  2. Slide the battery cover toward the bottom of the phone. Lift and remove the back cover from the phone.
    • Slide the battery cover toward the bottom of the phone.
    • Lift and remove the back cover from the phone.
  3. Remove the battery from its compartment.
    • Remove the battery from its compartment.
    • Pinch the end of cord where the battery is attached to the phone and pull up gently.
Conclusión
6 personas más completaron esta guía.
Arbitrary Name
Miembro Desde 28/01/15
1,083 Reputación
4 Guías creadas
Equipo
Penn State, Team 1-8, Kaschak Winter 2015 Miembro de Penn State, Team 1-8, Kaschak Winter 2015
PSU-KASCHAK-W15S1G8
4 Miembros
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 298
