Saltar al contenido principal
Ultimate Ears Wonderboom 3 Speaker Mesh Replacement
Qué necesitas
  1. Ultimate Ears Wonderboom 3 Speaker Mesh Replacement, Speaker Mesh: paso 1, imagen 1 de 3 Ultimate Ears Wonderboom 3 Speaker Mesh Replacement, Speaker Mesh: paso 1, imagen 2 de 3 Ultimate Ears Wonderboom 3 Speaker Mesh Replacement, Speaker Mesh: paso 1, imagen 3 de 3
    • To unclip the top of the speaker from the body, insert the metal spudger to the left of the speaker's center. To find the correct position, make sure the pointed end of the spudger is inserted entirely.
    • While in this position, press down and into the speaker to unclip the top. You should feel and hear and audible click.
    • Repeat this on all four sides of the speaker. The speaker's top will snap off when you press down on it, so make sure you hold onto the top so it does not fly off.
  2. Ultimate Ears Wonderboom 3 Speaker Mesh Replacement: paso 2, imagen 1 de 1
    • Take the top off of the speaker to reveal the inside of the speaker.
    • Carefully set the top cover to the side and make sure the clear plastic button tabs stay intact.
  3. Ultimate Ears Wonderboom 3 Speaker Mesh Replacement: paso 3, imagen 1 de 2 Ultimate Ears Wonderboom 3 Speaker Mesh Replacement: paso 3, imagen 2 de 2
    • Take the mesh covering off of the speaker by pressing on the center of the speaker and pulling the mesh upwards.
Conclusión
2 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 38
Todo El Tiempo: 331
