Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide will show you how to replace the battery of your Udi U818A FPV drone controller. You will need a JIS #0 screwdriver to complete this task.
Partes
No se especificaron partes.
  1. Turn the remote control over so that the buttons and joysticks are facing downward.
    • Turn the remote control over so that the buttons and joysticks are facing downward.
  2. Kit de Destornilladores Manta
    112 bits for every fix.
    Upgrade Your Toolbox
  3. Using a JIS #0, unscrew the silver 4mm screw that holds the battery cover in place.
    • Using a JIS #0, unscrew the silver 4mm screw that holds the battery cover in place.
  4. Open the battery access panel.
    • Open the battery access panel.
    • Disconnect the red and black wires.
    • Remove the depleted battery.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 99
