Saltar al contenido principal
UTStarcom XV6700 Camera Replacement
Qué necesitas
  1. UTStarcom XV6700 Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Press the on/off button on the top to power the phone off.
  2. UTStarcom XV6700 Camera Replacement: paso 2, imagen 1 de 1
    • Remove the battery cover by pressing and sliding the cover down and off of the phone.
  3. UTStarcom XV6700 Camera Replacement: paso 3, imagen 1 de 3 UTStarcom XV6700 Camera Replacement: paso 3, imagen 2 de 3 UTStarcom XV6700 Camera Replacement: paso 3, imagen 3 de 3
    • Pull the battery removal tab and lift the battery out of the phone.
    • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
  4. UTStarcom XV6700 Camera Replacement, Camera: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
  5. UTStarcom XV6700 Camera Replacement: paso 5, imagen 1 de 2 UTStarcom XV6700 Camera Replacement: paso 5, imagen 2 de 2
    • Use firm pressure to carefully pry off the cover with your fingers.
  6. UTStarcom XV6700 Camera Replacement: paso 6, imagen 1 de 1
    • Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board. The board is still connected by a connector on the bottom of the board.
  7. UTStarcom XV6700 Camera Replacement: paso 7, imagen 1 de 1
    • Gently pry off the camera flash circuit board with the spudger.
  8. UTStarcom XV6700 Camera Replacement: paso 8, imagen 1 de 1
    • Gently pry off the camera with the spudger.
Conclusión
Jesse Walker
Miembro Desde 06/04/13
201 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 186
