Saltar al contenido principal
UTStarcom CDM8945vw Logic Board Replacement
Qué necesitas
  1. UTStarcom CDM8945vw Logic Board Replacement, Battery: paso 1, imagen 1 de 1
    • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
  2. UTStarcom CDM8945vw Logic Board Replacement: paso 2, imagen 1 de 1
    • Remove the battery.
  3. UTStarcom CDM8945vw Logic Board Replacement, Antenna: paso 3, imagen 1 de 1
    • Identify the antenna. It is the extendable plastic component pictured here.
  4. UTStarcom CDM8945vw Logic Board Replacement: paso 4, imagen 1 de 1
    • Twist the base in a counter-clockwise motion to unscrew the antenna.
  5. UTStarcom CDM8945vw Logic Board Replacement: paso 5, imagen 1 de 2 UTStarcom CDM8945vw Logic Board Replacement: paso 5, imagen 2 de 2
    • The antenna should slide right out of the phone when finished.
  6. UTStarcom CDM8945vw Logic Board Replacement, Speaker: paso 6, imagen 1 de 1
    • Remove the small rubber grommet using the plastic opening tool.
  7. UTStarcom CDM8945vw Logic Board Replacement: paso 7, imagen 1 de 1
    • Remove five screws using a Phillips #00 screwdriver.
  8. UTStarcom CDM8945vw Logic Board Replacement: paso 8, imagen 1 de 1
    • Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
    • Prying the two pieces apart may be difficult. Carefully apply a moderate amount of pressure when attempting to separate the two pieces or else you will risk breaking them.
  9. UTStarcom CDM8945vw Logic Board Replacement: paso 9, imagen 1 de 1
    • Remove the back piece of the outer case.
  10. UTStarcom CDM8945vw Logic Board Replacement: paso 10, imagen 1 de 1
    • Remove the speaker using a plastic opening tool.
    • Apply a small amount of force when removing the broken speaker from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
  11. UTStarcom CDM8945vw Logic Board Replacement: paso 11, imagen 1 de 2 UTStarcom CDM8945vw Logic Board Replacement: paso 11, imagen 2 de 2
    • Remove the wire attached to the speaker from the motherboard using tweezers.
    • Apply a small amount of force when removing the wire from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
  12. UTStarcom CDM8945vw Logic Board Replacement, Logic Board: paso 12, imagen 1 de 1
    • Detach the highlighted piece from the logic board using a plastic opening tool.
  13. UTStarcom CDM8945vw Logic Board Replacement: paso 13, imagen 1 de 2 UTStarcom CDM8945vw Logic Board Replacement: paso 13, imagen 2 de 2
    • Remove the logic board from the anterior piece of the outer case using the plastic opening tool.
Conclusión
Bilal
Miembro Desde 10/04/12
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 24-26, Regan Fall 2012 Miembro de Cal Poly, Team 24-26, Regan Fall 2012
CPSU-REGAN-F12S24G26
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 9
Todo El Tiempo: 309
