Saltar al contenido principal
USB 1020 Water Pump of DC 3.5-9V Replacement
Qué necesitas
  1. USB 1020 Water Pump of DC 3.5-9V Replacement, USB 1020 Water Pump of DC 3.5-9V: paso 1, imagen 1 de 2 USB 1020 Water Pump of DC 3.5-9V Replacement, USB 1020 Water Pump of DC 3.5-9V: paso 1, imagen 2 de 2
    • Unplug the USB-C cord from the fountain.
    • Only proceed with dry hands to prevent being electrocuted.
  2. USB 1020 Water Pump of DC 3.5-9V Replacement: paso 2, imagen 1 de 3 USB 1020 Water Pump of DC 3.5-9V Replacement: paso 2, imagen 2 de 3 USB 1020 Water Pump of DC 3.5-9V Replacement: paso 2, imagen 3 de 3
    • Carefully pull out the water pump by pulling the wire from the reservoir located at the back.
  3. USB 1020 Water Pump of DC 3.5-9V Replacement: paso 3, imagen 1 de 2 USB 1020 Water Pump of DC 3.5-9V Replacement: paso 3, imagen 2 de 2
    • Detach the old water pump from the tube by gently pulling on the pump.
  4. USB 1020 Water Pump of DC 3.5-9V Replacement: paso 4, imagen 1 de 1
    • Adjust the water pressure and flow on the new water pump.
    • Shift switch to the right to lower the pressure and left to increase the pressure.
  5. USB 1020 Water Pump of DC 3.5-9V Replacement: paso 5, imagen 1 de 3 USB 1020 Water Pump of DC 3.5-9V Replacement: paso 5, imagen 2 de 3 USB 1020 Water Pump of DC 3.5-9V Replacement: paso 5, imagen 3 de 3
    • Connect the new water pump to the tube.
    • Make sure you hear a click sound to ensure the connection is secure.
  6. USB 1020 Water Pump of DC 3.5-9V Replacement: paso 6, imagen 1 de 1
    • Place the new water pump into the reservoir.
  7. USB 1020 Water Pump of DC 3.5-9V Replacement: paso 7, imagen 1 de 2 USB 1020 Water Pump of DC 3.5-9V Replacement: paso 7, imagen 2 de 2
    • Plug in the USB-C cord to turn on the fountain.
    • Use dry hands to prevent being electrocuted.
Conclusión
With these easy-to-follow steps, you can seamlessly replace the water pump in your indoor fountain to keep it in excellent working condition.
Guneet Longia
Miembro Desde 01/30/23
159 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 122
